TIlt away stearing assembly help 69 gt500
Discussion in '1965-1970 Shelby Mustang GT350 & GT500' started by PaulWall2228, Oct 20, 2011.
  1. PaulWall2228
    PaulWall2228 Member
    Im trying to instal my tilt away stearing vacuum for my 1969 gt500. I dont know how it goes or how it is wired, any info would be helpful thanks.
    - found out how to wire but still having trouble mounting it, any help?
    -Figured it out
  2. Coralsnake
    We can probably help, if you are more specific
  3. PaulWall2228
    PaulWall2228 Member
    I need help finding where the vacum canister for the tilt away stearing on my 1969 shelby gt500 mustang fastback goes. My car is without
    AC. I believe it goes behind the dash somewhere, any help would be nice, thanks.
  4. Coralsnake
    Yes, you definetly need some help. The tilt air canister is located under the battery tray, on the exterior of the fender apron on a 1969. Here is a photo:
  5. PaulWall2228
    PaulWall2228 Member
    Is it still mounted under the battery tray if my car is without AC because i was told that if it has AC then its mounted their but not where it would be mounted without AC
  6. PaulWall2228
    PaulWall2228 Member
    Also can you please post a picture of how the vacum hoses run from the tank to the inside of the car through the fire wall, thanks.
