My 67 GT-500 has an SPEC cast into the rear differential carrier. A friend of mine has the same car but the rearend has no SPEC, but has a correct date code and looks original to the car. Does anyone know whether the SPEC is supposed to be on all GT-500's or ?? Thanks, Dave
As I understand it Shelby was the first to put a nodular rear end center section in. Before the N was cast into the carrier, a SPEC was cast in place of the date code. Use the link below, click on rear ends in the left column. http://www.nvsaac.com/shelbyparts/Shelby_tech_main.htm
The embossed "N" case's were to start appearing on the 681/2 KR's and other Cobra Jet's but some foundry issue's delayed the "N" casting's being cast until the 69 model year. HTH. Frank
