Restoring a 68 GT500
Discussion in '1965-1970 Shelby Mustang GT350 & GT500' started by cobra427, Feb 14, 2008.
  1. cobra427
    cobra427 Well-Known Member
    GA
    I am restoring my 68 GT500 after being apart for about 10 years. The engine is out and the engine bay has been cleaned and primered, do I paint the engine bay black, install the engine then paint the car or paint the car first? The car is highland green and looks like the one on the 68 Shelby web site. The floor pans look just as good with 40 year old paint.
    I looked for a build sheet behind the interment cluster and under the carpet but no luck, any more ideas.
    I'll see if I can post some pics of what I have so far.
    The car is 00363.
    Gary
  2. TLEA
    Hi Gary,
    The way they were done at the factory was, primer then body color, then blackout. You will also be happier installing the engine after all bodywork/paint is done. Visit Pete's website and checkout his page on paint.
    http://www.thecoralsnake.com/PAINT.HTML
    Tim
  3. cobra427
    GA
    Cool I was at his site but didn't see all of that.
    Thanks
    Gary
  4. d_ford
    d_ford Well-Known Member
    Nelsonville, Ohio
    The way I did my fastback may not be the correct sequence but it worked out good. I painted all the black including the engine bay while it was apart and on the rotissorie. Then we masked off the engine bay and underneath when the body color was applied. It was less masking to do it that way rather than masking off the painted body to spray the engine compartment last.
  5. OVERRIDE
    OVERRIDE Well-Known Member
    elgin il
    Hi Gary
    When i had my 68 GT500 i found the build sheet folded up i a small square behind the speed-o . It was attached to cap screw that held the clip that held the main wire harness.
  6. highland green
    highland green Well-Known Member
    My build sheet was folded in a very small square, secured by a fine wire ,high on the left side of the steering wheel, behind the dash.
