How Do I Replace An Original + Battery Terminal Cable End On A Rear Battery 65 GT350?
Discussion in '1965-1970 Shelby Mustang GT350 & GT500' started by SFM 5025, Apr 28, 2008.
  1. SFM 5025
    SFM 5025 Active Member
    Greetings All,
    Unfortunately, the day has come where I must replace the original positive battery terminal cable end on SFM 5025.
    Of course, this is on a rear battery car, and I do not want to replace the entire cable (because it is original with all the unique factory rivits holding up the cable the entire length of the car)--hence the problem.
    Has anyone ever done this?
    All I can think to do is to maybe buy a doner short positive battery cable and somehow uncrimp it and then somehow recrimp it back on? Or are maybe repops available uncrimped and uninstalled???
    I'm stumped--what do ya'll think?
    Thank you very much in advance.
    Neil
  2. steveshelbymustang
    Re: How Do I Replace An Original + Battery Terminal Cable End On A Rear Battery 65 GT
    Not sure if your end had the heat shrink or inserted into lead terminal without. Either way you'll need a crimper to crimp the lead onto the cable end. A hand crimper may work so you don't have to remove the cable just not sure how tight the hand crimper will do in place of a hydraulic crimp.
  3. Texas Swede
    Hi Neil,
    I think Jim Cowles sells excellent positive connectors which you can
    solder on to the end. Don't forget to put the shrink tube on first
    and move a bit up the cable and then pull it over the end and treat it with a heat gun. Did this on my 65 many years ago but it was easier as the
    cable was out of the car.
    Good luck.
    Texas Swede
  4. shelby6t5
    shelby6t5 Well-Known Member
    Jim is the man with that stuff.
    Can you post pix of the cable retainers and clips for the rest of the members?
  5. Texas Swede
    Here is a picture of the trunk of 5S275.
    Texas Swede
  6. shelby6t5
    Are those the vent caps Kurt made?
  7. Texas Swede
    Mike,
    Yes, and they fit very well and look great.
    Not original, but what do you do when originals
    can't be found for a price I could afford.
    Also, as regards the tar top battery you asked about.
    I bought a repo from a company that made a tar top
    with reverse posts that I now use instead of the
    original Sta-Ful on the picture which is dead.
    Can't remember the name of the company but could probably
    find it somewhere if you are interested. #17 probably need
    the Ford post arrangemnt which is a standard part for the
    company in question. My Cobra Vent Caps don't fit well in the repo
    though so I may charge another dry charged green text battery I have
    24C.
    Texas Swede
