help with vacuum hoses
Discussion in '1965-1970 Shelby Mustang GT350 & GT500' started by lucky 31, Jan 12, 2014.
  1. lucky 31
    lucky 31 Member
    north carolina
    restoring 70 gt500 anyone know a website or can give any help on hooking up the vacuum hoses on engine thanks 31
  2. mrmustang
    The SAACforum can help.
    Also, when you post, you should let them know whether you have AC, tilt wheel, emissions, how many ports are on your vacuum "block" etc.
    Pictures will help as well as the last four of your VIN (for running changes).
    Bill S.
  3. Coralsnake
    Which transmission?
  4. lucky 31
    lucky 31 Member
    north carolina
    thanks for the response vin# 3142, 4 speed manual,no air condition , try to get a picture on tomorrow
  5. Coralsnake
    On a 4spd you should have a dual vacuum advance and a three way vacuum tree on the thermostat housing. From memory...
    The yellow striped line goes from the top of the vacuum tree to the carb
    The green striped line goes from the middle vacuum tree port to the front of the advance
    The red striped line goes from the back of the vacuum advance to the bottom of the tree, it also has a t that goes to the front intake manifold fitting.
    The black hose goes from the anti backfire can of the smog to the rear intake fitting.
  6. lucky 31
    lucky 31 Member
    north carolina
    thanks for the help. Hope to get it fired up soon.
