Has anyone restored their original steel framed fiberglass covered deck lid for a 67 Shelby. I aquired one that is very original with the shelby part numbers cast into the bottom of the spoiler. The top surface is thin and wavy with lots of bumps in it. I suspect the gel coat is cracked and making all the humps and bumps stick up. The steel frame appears to be solid too. I don't know much about fiberglass repair. Would you sand down the surface as not to go through the matting and have the surface built up by spraying on gel coat to give it a more rigid surface? If you press on the humps they go in and out like an oil can. Thanks Randy
rcgt350, Just kind of curious about the trunk lid you are trying to repair. I have never seen a '67 Shelby trunk lid that had a steel frame. All the ones I have ever seen are of all fibreglass construction. Could you provide the Shelby part number that appears on that trunk lid? I would like to cross reference that number to the '67 Shelby parts list that I have. Thanks, shlby66.
Please correct me if I'm wrong but aren't the.... early '67 hoods steel-framed with fiberglass overlay and the trunks are fiberglass only? That's a question. I know my '67 G.T.500 #330 has a hood like that and I think the trunk is fiberglass.
Well folks, with a little research in the Shelby Bible, ( Shelby American World Registery, page 617 ) in the section labled Running Production Changes, under "Hoods & Trunk Lids" : Early cars had fiberglass hoods and trunk lids with steel frames; later cars had one-piece, all fiberglass hoods and trunk lids. Some cars had a combination of each. As to rcgt350's dilemma of how to repair his trunk lid, I can tell you it will take more time and effort than you think. I repaired/rebuilt the steel framed hood on my '66 Shelby. Basically you have to separate the steel frame from the fiberglass shell. Then rebond the two pieces back together. After all this time, the bonding material just gives up and you end up with a hood or trunk lid with the mentioned waves, bumps and soft spots. It can be done, but I will buy a new hood next time and hang the old one on my garage wall. shlby66 1967 GT350 #1688
If you had a major crack along the spoiler lip - on top - I'd say de-laminate it to put extra fiberglass on the inside. That would stiffen it up. If not, yes sand it down. I don't think putting extra gel coats is going to help. But, the newer types of paint do allow some flexing without cracking. Fiberglass does show some surface imperfections. Take a good long look at any 60's Corvette. History on the Fiberglass/steel deck lids/Hoods: original on cars below #300, between #300 and #400 either front or rear (not hard and fast rule) over car #450, could have but unlikely. Note I said original installations. I've seen wrecked and rebuilt early cars with out the steel/glass hoods because of replacement parts being all glass.
