07 GT500 Wheel hop --Best new Lowers?
Discussion in '2nd Generation Shelby Mustangs' started by OSHELBYO, Jan 31, 2009.
  1. OSHELBYO
    OSHELBYO New Member
    To solve the wheel hop issue...what is the best thing to do. I know a bunch of you are just changing the lowers. If so which lowers are the BEST to stop the wheel hop!
    I do not want to change the car from looking stock...with height or anything...I just don't want the wheel hop.
    OSHELBYO
  2. 67GT500#2100
    The upper is a key part to stopping wheel hop also. I used Metco lowers and adjustable upper and wheel hop was completely eliminated. I did not notice any change in ride height.
  3. gsharapa
    gsharapa Member
    Dallas, Texas
    All you need to do is put the Ford Racing lowering springs in and it will eliminate the wheel hop. I have a stage II kit on my car (pulley, cold air and tune) as do 3 of my friends and all we did was put the lowering springs in and all 4 cars do not have wheel hop any longer even with the 135 HP increase............
  4. socalwrench
    socalwrench Member
    Acton
    Changing the pinion angle will reduce wheel hop, as the axle housing tends to twist up and down under torque.
    I would not worry about the lower control arms. I would buy an adjustable upper arm first.
  5. frydguy79
    frydguy79 Member
    LAND OF AAHHS
    J&M upper control arm, get the adjustable one if you are going to lower the car ever, and J&M lower control ams, no need for adjustable ones there, and you are good to go, 5500 rpm launches with no hop:thumbup:
  6. amar3549
    amar3549 New Member
    hey bud iv just got the same thing done to my car cold airintake, pulley, sct flash tunner, borla exhaust, highperformance spark plugs how much horsepower do you think i would be making now ? thanks ma n
  7. baknblk
    baknblk New Member
    All that is needed for the wheel hop is a pinion snubber.
