70 Shelby GT500 Clock Info
Discussion in 'Lost, Found & Looking' started by Coolhandluca, Apr 24, 2008.
  1. Coolhandluca
    Coolhandluca Member
    Southeast Louisiana
    I own # 2965 and the clock (Original) is mounted externally in a black plastic housing. I was told this was b/c of the Dealer air evaporator prevented the clock depth as in the other cars. I have never seen another Shelby or pic of this clock. Anyone with any information about this would be greatly appreciated. The clock still works although a kid broke into my car for the stereo and cracked the clock face. I was planning to remove the clock b/c the stereo has a digital clock already and I don't like the look of the old clock.
    I need to take a pic of this clock as I owned the car since 1974 and never took a pic of the dash. I guess if someone needs this to complete a car I will sell it. I also have the original evaporator and housing from the dealer air. I swapped the dash to a factory unit for the extra ducts since I only had one big one in the middle.
  2. markboss
    markboss Well-Known Member
    I have seen a 70 GT350, with the same type of clock...It was equipped with an ARA aftermarket air conditioner...
    I have heard of a few of these type clocks, looks kinda weird...
  3. Bob Gaines
    The item you are discribing is not a assembly line installation but one needed when installing a dealer add on air unit. They are not desirable and any thing you get for it will be found money in my opinion. I would eliminate the big clock especialy since you changed out the lower dash and can now install more assembly line appearing components. Bob
  4. Coolhandluca
    Coolhandluca Member
    Southeast Louisiana
    Thank You. I didn't want to use it and wasn't sure if I should remove it. The only problem is the monting screw holes left in the dash from it. Since it is a mustanf part (Woodgrain Look) I'm sure I can find a replacement.
