looking for shelby hood scoop
Discussion in '2nd Generation Shelby Mustangs' started by my07clone, Apr 14, 2008.
  1. my07clone
    my07clone Member
    I am working on a car with/for my son and am looking for the authentic Shelby hood scoop for a 2007 GT - the one with the "fake" mounting bolts around the edge. Does anyone know where I can buy one? We tried our local Ford dealer but they had no idea.
  2. 67GT500#2100
    I think you mean the Shelby GT scoop?
  3. my07clone
    my07clone Member
    yes thats the one
    I know a lot of people think that one is tacky but my son and I like that one for some reason
  4. 67GT500#2100
    I heard that you can only get one with a work order and a vin from an original Shelby GT. I don't know for sure though.:confused:
  5. my07clone
    my07clone Member
    I thought there could be a chance that is true. If that's the case I will just settle for whatever looks the closest possibly with no drilling.
  6. tesgt350
    With no Drilling? I have bad news for you.........That 2007 Shelby GT Hood Scoop Rivits on. All of those little silver dots around it in the Photo are Rivits. That is a LOT of tiny Holes to be drilled in the Hood. Several Mustang Parts Suppliers do offer the 1965 - 1966 Hood Scoop as a "Bolt On" or a "Bond On".
  7. my07clone
    my07clone Member
    oh, someone told me those were fake around the edges
    do you know where I can buy a similar copy - prefer bond not bolt
  8. rnoggle
    rnoggle Member
  9. my07clone
    my07clone Member
    thanks I will watch that one closely
    on our car I put down a vinyl stripe kit, blue base with white stripe
    with the rivets on that scoop do you think I can lay down vinyl again?
    or will I have to paint it to match?
  10. rnoggle
    rnoggle Member
    The scoop is originally painted silver with a body color vinyl stripe down the center.
    I think it would be pretty hard to lay vinyl down over the scoop to match the car. Probably a whole lot easier to get the scoop pinted to match the car. The "rivit" heads are painted also.
  11. tesgt350
    WOW, I did not know that. They did a good job faking it......:laf: Now I know what they are talking about with the Scoop Problems (lifting on the edges).
  12. tesgt350
    For a "No Drilling Needed" Hood Scoop go to Ebay and type in "Mustang Hood Scoop" and you should find a few to choose from like these..........
  13. rnoggle
    rnoggle Member
    Yeah, when I sit in the drivers seat, I can lookthru the winshield and see daylight between the rear edge of the scoop and the hood. Not as bad in the warm weather as it is in the cold. Also on the drivers side of the scoop, it is lifting about 1/8 inch, right in the middle.
  14. tesgt350
    Is the Scoop made of Injection Molded Plastic or is it Fiberglass?
  15. tesgt350
    Maybe it would be better to drill out the "FAKE" Rivits and actually Rivit the scoop to the Hood using the same Holes.
  16. rnoggle
    rnoggle Member
    The problem with that is that the hood itself is a thinner, weaker material (aluminum) than the scoop (thick plastic). Instead of pulling the scoop down tight, it causes the hood to distort.
    Shelby supposedly is working on a new scoop for the SGT as a warranty replacement. They aren't having much luck getting anything finished though.
  17. stump_breaker
    stump_breaker New Member
    The first gen scoop is held on with 8 bolts underneath. Four are hid by the blanket. The second gen scoop has the two front fake rivets (which are actually just bolts that have been trimmed) replaced with two long bolts through the hood. The "final fix" as of now (per Amy it may not be) is to remove the fake rivets and actually rivet the scoop to the hood. Mine looks great.
    If you want my scoop I'll give it to you.......
    .......in exchange for a KR hood painted, striped and installed on my car! :alarm:
  18. Shelby07GT
    Shelby07GT New Member
    The rivets are not "FAKE" like everyone says they are. the 07 and 08 Shelby Shelby Gt Mustangs all have exactly 25 aluminum rivets that hold the scoop to the hood. In 07 there was a recall on the scoops and if you took your scoop off and sent it to Shelby American they would send you a new scoop covered under the recall. And the only way you could do that is by proof of ownership (Vin# & Registration) And you also needed to register your 2007-2008 Shelby GT with Shelby American. And only then could you get a replacement scoop for around $170. I always thought the rivets were FAKE too until I bought my 07 with an aftermarket Cervinis Ram Air KR Style Hood. Because I got the original hood with the car minus the scoop. Which I am looking at as I type this..good luck
