Steering wheel question - 1967 GT500
Discussion in '1965-1970 Shelby Mustang GT350 & GT500' started by Jimmy J1, Jan 3, 2008.
  1. Jimmy J1
    Jimmy J1 Well-Known Member
    Tampa, FL
    Hi,
    The wheel on my 67 GT500 has an issue. One of the two wires to the horn button is no longer connected to the stainless steel ring on the back. Anyone ever try to repair this problem first hand?
  2. Bob Gaines
    Yes, PM me and I will give you my number .Easier to explain on the phone then to type.
  3. rsimkins
    rsimkins Well-Known Member
    Eastcoast USA
    Seems to be a common problem with these wheels, any chance of publishing a detailed repair or maybe recording an audio file and posting that? Thanks.
  4. Bob Gaines
    Roy I'll PM you with my number and tell you and you can type it all.
  5. Jimmy J1
    Tampa, FL
    I got off fairly easy on this one. Bob and Dave were kind enough to give me the info on the job. I drilled in through the rear of the hub between the two contact rings at about 12 o'clock. I drilled two holes side by side and then ran them together. Luckily my bad wire was right there where it had come loose from the ring. How it came loose while packed in that epoxy is a mystery. There were no burns. The remainder of the wire was still held tightly in the epoxy. I was prepared to drill through and replace both wires. I decided to take the short way out and reattached the wire to the ring and it made good contact. I checked it with an ohm meter. I tugged on both wires from the front and they were still held tightly by the epoxy. I then filled the hole back in with some epoxy putty. It is working fine now. It is a very tight area to work in. I was ready for the big job with camera ready. I can post some pictures of as far as I got, but you can't see much down in the hole. Thanks again to Bob Gaines and David Randal for the advice. :thumbsup:
  6. Texas Swede
    My 67 horn gave up many years ago and I solved it with a
    separate relay. Do you guys think that this problem solver may
    make my relay obsolete.
    Texas Swede
  7. Bob Gaines
    if it isn't the wheel it is a bad ground but sounds like a wheel problem.
  8. Texas Swede
    Thanks Bob,
    Could you send me the solution as well?
    Also, do I need to remove the steering wheel
    to apply the fix?
    /Bo Sewallius alias Texas Swede
  9. Shelboss
    Shelboss Member
    Boston, MA
    I had a machinist drill the rings from the back with about 3/16" holes and turn a couple of contacts to press fit into the rings. We soldered new wires to the contacts, fed the wires up thru the original location, and pressed the contacts flush. It has worked great for many years!
