2007 Ford Shelby GT500 Is Most Powerful Mustang Ever
Discussion in 'Shelby News Forum' started by rshelby, Feb 6, 2006.
    DETROIT, February 1, 2006 - After 40 years, racing legend Carroll Shelby and the Ford Mustang are back together with the introduction of the most powerful Mustang ever built, the 2007 Ford Shelby GT500.
    A modern interpretation of the Shelby Mustang of the 1960s, the Ford Shelby GT500 features a 5.4-liter supercharged V-8 that generates 475 horsepower.
    True to the original GT500, it will be available both as a coupe and as a convertible when it goes on sale in the summer of 2006.
    "When Carroll was developing the original GT350 and GT500, he wanted to build the most powerful, most capable Mustangs of his day," says Hau Thai-Tang, director, Advanced Product Creation and Special Vehicle Team (SVT). "Our goal was to build the most powerful, most capable Mustang ever."
    Serving as touchstone and inspirational leader for both the concept and the production versions, Shelby was impressed by what the team has accomplished.
    "It's one thing to put 450 horsepower in an exotic supercar," says Shelby. "It's another to put that much power in something as affordable as a Mustang. The fact that they not only met their goal but pushed on to 475 horsepower is a remarkable achievement."
    As expected of anything with Shelby's name on it, the heart of the car is what's under the hood. The Ford Shelby GT500's supercharged 5.4-liter, 32-valve V-8 evolves from Ford's experience with tuning its modular, or MOD, engines. Output is a brawny 475 horsepower.
    The engine is force-fed an air-and-fuel mixture via a "Roots-type" supercharger providing 8.5 pounds per square inch of boost. The GT500 uses a cast-iron engine block. It borrows from the Ford GT program aluminum, four-valve cylinder heads, piston rings and bearings, adding a high level of performance durability to the drivetrain. Helping put the power to the pavement is a 6-speed manual gearbox.
    SVT engineers retuned and upgraded key chassis components. Improvements such as revised shocks, spring rates and upgraded stabilizer bars help the Ford Shelby GT500 stop and turn with the same authority as it goes.
    The Ford Shelby GT500 features a MacPherson strut independent front suspension with Reverse L lower control arms, and a solid-axle, three-link rear suspension with coil springs and a Panhard rod for precise control of the rear axle. This rear suspension design has been validated on the track by Ford Racing.
    To match this power and handling ability, engineers fitted some of the biggest brakes in the business to the Ford Shelby GT500. Four-piston Brembo calipers are fitted to 14-inch Brembo vented rotors up front, and 11.8-inch vented discs in the rear continue SVT's legacy of great-braking Mustangs. Secure footing is provided by 255/45ZR high-performance tires in front and 285/40ZR high-performance tires in back. Wheels are 18 inches by 9.5 inches.
    Matching the GT500's performance under the hood is its striking exterior design. A sinister-looking front-end design includes wide upper and lower fascia openings with a functional air splitter. The upper intake sports the famous Cobra logo floating off-center in place of a centered galloping pony found on other Mustangs. On either side, slanting headlamp openings add to the dramatic front appearance.
    The bulging hood has heat extractors protruding near the leading edge, combining to provide improved airflow and aerodynamics. As air passes over the hood, hot air from the engine compartment is drawn out through ducts attached to the hood extractors.
    "The restrained, performance-oriented SVT design theme has become instantly recognizable to enthusiasts without brash styling cues," says Doug Gaffka, design director, Ford SVT vehicles. "The GT500 takes a huge leap forward by combining the modern Mustang muscle car with the classic Shelby performance look."
    The production Ford Shelby GT500 Coupe comes punctuated by the classic Le Mans-style white stripes that race along the top from nose to tail. The stripes recall the Shelby Mustangs that marked another important 1960s Mustang transition when Ford put it on the track to becoming a racing legend. The GT500 nomenclature is prominent in the lower bodyside racing stripe, another cue from the classic Shelby Mustangs.
    In a touch also borrowed from the GT500's past, no Le Mans stripes will be seen on the 2007 Ford Shelby GT500 Convertible. However, the convertible will sport a cloth top similar to those fond on pricier convertibles.
    The unique rear fascia features lower strakes inspired by the Ford GT's integrated rear airflow diffuser, and a rear spoiler reminiscent of a classic GT500. To mark the collaboration of two Mustang performance icons, the GT500 features Shelby and SVT badging.
    The fenders each feature an updated design of the Cobra. The front grille features an off-center snake in place of the standard running horse. "GT500" is emblazoned inside the side rocker stripes, and the name SHELBY is prominently written across the rear deck. The SVT logo can be seen on the wheel center caps, a signature SVT location, as well as on the doorsill plates. To top it off, the medallion between the taillights reads "Shelby GT500" centered on the Cobra image.
    Inside, too, upgraded levels of flair and function abound. The locations of the speedometer and the tachometer are swapped to provide performance-oriented drivers with a better view of shift points while changing gears. Front seats have received additional lateral support to help keep the driver optimally positioned during cornering. The interior is offered in a choice of two colors, Charcoal Black or Charcoal Black and Crimson Red. The charcoal/red offering features Crimson Red seating surfaces and door panel inserts. Seating surfaces are leather with both interior treatments. Snake logos embossed in the seat backs finish the package.
    The Shelby GT500 script and Cobra image are repeated on the steering wheel cap. Behind the wheel, the gauges wear lightfaces in keeping with SVT tradition. The chromed accessories inside the cabin have been replaced with a satin aluminum finish, including the aluminum shift lever knob that is nicely positioned for quick, positive shifts.
    The Ford Shelby GT500 will be built at the Ford-Mazda joint venture, AutoAlliance International, in Flat Rock, Mich.
    http://media.ford.com/newsroom/feature_display.cfm?release=22364
  2. dj_b0by
    dj_b0by Member
    romania/craiova
    photos of what would it look like or what it looks like???:rolleyes:
  3. DeLa1Rob
    Boby,
    There are lots of images in the Gallery section. See here.
  4. dj_b0by
    dj_b0by Member
    romania/craiova
    thanks man will do:)
