67 GT500 single or dual belt ??
Discussion in '1965-1970 Shelby Mustang GT350 & GT500' started by onelimegold, Nov 8, 2014.
  1. onelimegold
    onelimegold Active Member
    canada
    Need to know if i have to go with single or dual alternator belts ?? My car is a late 67 GT500 with no a/c and no smog . belt length would be appreciated as well ( 42'' or 44'' ) . thanks in advance .
  2. Bob Gaines
    No A/C and no smog would be a duel alt pulley and belts. Many 67 GT50's have had the waterpump ,crank and P/S pulley's changed . In this case the crank pulley changed to the wrong one will not allow the correct belts to be used. With the correct pulleys and the correct original belts (Marti belts are the closest modern equivalent ) the adjustment will be mid way in the bracket regardless of what item you are trying to adjust on the engine. Do you know which dampener and crank pulley is correct for your engine?If you don't you are working blind. The correct damper will not accept many alternate pulleys .The right crank pulley will not fit the wrong dampener correctly.
