Will 2014 GT500 rear brakes fit a 2007 GT500
Discussion in '2nd Generation Shelby Mustangs' started by stevethemechanic, Jul 5, 2014.
  1. stevethemechanic
    stevethemechanic New Member
    Does anyone know if this will work by replacing the caliper brackets & rear rotors from 14 on a 2007 any experience here will help
  2. Dubya
    Dubya New Member
    Yes they should..... you need to but the brackets and of course rotors for the 13-14...they use the same pads...it is a bit involved but quite doable...have to pull axles and pull diff cover and replace diff fluid,,,
