1966 GT350 upper A-arm problem
Discussion in 'Introductions and Greetings' started by wgsmith1936, Sep 2, 2013.
  1. wgsmith1936
    wgsmith1936 New Member
    Atlanta, GA
    Replacing the suspension on my original 66 GT350 and notice the A-arm inclination angle at the mounting points to the body differ significantly from driver side to passenger side. On other Mustangs the angles are the same. I think the angle of the arms should be perpendicular to the slightly inclined from vertical shot tower indentations. On mine the driver side is close to horizontal and the passenger side is significantly greater than the correct angle. Very easy to see. Looks like someone was very sloppy when drilling the arm mounting holes on the assembly line.
    Anyone else have this problem ?
    Any suggestions for repair ?
    Thanks, WGS
