68 KR ignition timing
Discussion in '1965-1970 Shelby Mustang GT350 & GT500' started by waltweems, Mar 27, 2013.
  1. waltweems
    waltweems New Member
    I had my engine rebuilt last year and now have it back in and running. I set the timing to 10 degree advance with
    the vacuum lines attached and 20 degrees when unattached. all Original including distributor. Car ran great until i hooked up the smog and now it backfires. Anyone have any thoughts? Is the advance OK?
    Walt Weems
  2. zrayr
    zrayr Well-Known Member
    TX
    it should be set to the factory spec. with the distributor vacuum line plugged. I think the 10 degree BTDC is the number at idle you should be using.
    Z.
  3. waltweems
    I have my timing set for 10 degree advance and the car does run well but, when I connect the smog pump
    it backfires. Any thoughts on the backfire issue?
    Walt Weems
