Ford Racing Aluminum Short Block,NEW
Discussion in 'Dealer & Vendor Forum' started by et9secstang, Oct 12, 2011.
  1. et9secstang
    et9secstang New Member
    ford racing shortblock, NEW. in the original crate from Ford, part number M-6009-a-463SC,
    fits 2005-2010 mustang Gt
    Forged steel 8 bolt crank
    forged steel H beam rods
    forged aluminum 16cc dish 3 valve pistons
    new oil pump
    Uses M-6010-A56NA block, knock sensor bosses are not removed from the block
    Approximately 8.7:1 compression ratio when used with 50.3 cc 3 valve heads
    lower compression for supercharger applications
    built with ALL NEW PARTS
    will accept 3V cylinder heads
    8 bolt flywheel required
    This is brand new ,no BS
    I will take 3K for the engine plus shipping
    I accept certified funds, pay pay plus the 3% handling fees, I will also accept personal check but I will only ship after checks clears my bank or you can pick it up in person if you have cash.
    I can be reached at keithspitstop@comcast.net
    thanks for looking
