'67 GT500 Part Finishing
Discussion in '1965-1970 Shelby Mustang GT350 & GT500' started by DAdams, May 18, 2011.
  1. DAdams
    DAdams Active Member
    Texas
    Please provide direction on correct finishes (paint, phosphate, bare, etc) for the following. Car is a March 67 build if it matters.
    -Oil filler tube (pressed into intake)
    -Shock tower brackets
    -Sway bar brackets
    -Throttle return spring bracket
    -Throttle rod from carb to pedal rod(bellcrank???)
    Thank you for the help...
  2. Bob Gaines
    -Oil filler tube (pressed into intake)- black semigloss
    -Shock tower brackets-black semigloss
    -Sway bar brackets -bare steel
    -Throttle return spring bracket- zinc silver
    -Throttle rod from carb to pedal rod - was zinc silver most of the time but have seen a few zinc phosphate gray. Bellcrank -zinc silver I hope this helps. Bob
    rshelby likes this.
  3. DAdams
    Texas
    Thank you for the help Bob...
