Free Window Sticker For Your Shelby
Discussion in '2nd Generation Shelby Mustangs' started by DS1516pb, Sep 6, 2010.
  1. DS1516pb
    DS1516pb Banned
    http://services.forddirect.fordvehicles.com/inventory/WindowSticker.pdf?vin=
    Right after the "=" sign put your entire VIN number in there and a printable download and disk savable PDF window sticker for your car should come up.
    It worked fine for me...however I found my original in my 2007 Shelby Owner's Manual. And had it laminated last night it was in great shape. But I still tried my VIN number out on this link I found while looking for something else. And there was my window sticker again! It might save you $45 from purchasing one from Ford if it works.
    Happy Labor Day everyone.
    Regards
    Dan
  2. R3troGT
    R3troGT Member
    Etobicoke, Canada
    I did this shortly after I got my Shelby and it worked no problem. This way I could print a nice clean copy with no creases from the dealer folding the original one
  3. Omicron
    Omicron Member
    Boulder County, CO
    Very cool, thanks for sharing this!
  4. dkaiser
    dkaiser Member
    Link does not work for me.:(
  5. Omicron
    Omicron Member
    Boulder County, CO
    did you put your vin number as the latter part of the URL? You have to otherwise it goes to nothing...
  6. dkaiser
    dkaiser Member
    Yes I did and it says page appears broken
  7. Omicron
    Omicron Member
    Boulder County, CO
    Usually when you get a "page broken" response it's because your browser isn't compatible with what's being loaded, a firewall somewhere is blocking your request or the site's response, or because the URL is wrong. Maybe try another browser or from another location. I tried putting in some different VIN combos and got things like "The VIN entered was not found in our system. VIN requested is 1ZVHT85H475318999" and "The VIN entered has the wrong length. VIN requested is 1ZVHT." Hope this helps!
  8. grabber_blue
    grabber_blue New Member
    It worked for me and mine is Canadian!
  9. dkaiser
    dkaiser Member
  10. grabber_blue
    That's strange. What browser are you using? I clicked on the link and IE8 expanded the URL correctly for me.
    If you copy the URL text from the first post and then paste it, yeah it won't work because you're copying the URL compressed display. Or if you type what you see in post #1 into the browser it won't work either.
    Copy this into your browser and add your VIN onto the end: services.forddirect.fordvehicles.com/inventory/WindowSticker.pdf?vin=
  11. dkaiser
    dkaiser Member
    I use IE8 & Firefox.
  12. rdrumm
    rdrumm Active Member
    Anaheim Calif
    Worked for me! Thanks!!!
  13. DADSDREEM
    DADSDREEM New Member
    Worked for me and my 2010 GT500. Thanks!
  14. cjspack
    cjspack Member
    Southern Ohio
    Thanks for the info on the window sticker. Even though I do have the original, it is cool to have it on an 81/2 x 11 sheet and not all folded up.
  15. crawlina
    crawlina New Member
  16. meterman
    meterman Member
  17. MNJarhead
    MNJarhead Member
    Germany
    Worked for my 2008. Does anyone know of a site like this for the older cars? It didn't work for my 78 or my 83.
  18. Rs4ockies
    Rs4ockies New Member
    Worked for me...thanks for the post. Helped with my car shopping efforts as well! Cheers
  19. Moncho
    Moncho New Member
    Thanks grabber_blue, & op for putting this info out.
    This worked for me.:thumbsup:
    Cheers,
    Moncho
  20. taz401
    taz401 New Member
    Oklahoma City
    worked for me..thanks...
